What is the charging voltage on a 1977 Merc 50 hp?
Flying Scott
Charging voltage on my engine is 18, and I've been told by other Merc owners that this is normal. Seems high to me. What do you think?
That motor would have an unregulated charging system, of maybe 9A. The battery is used as a voltage regulator. You may see 16VDC with a fully-charged battery. I expect 18V is too high, and you should confirm the accuracy of your meter, and that your battery and charging cables are clean and tight.
