Put a block of wood on top of the drive and trim the rams up. It will push the drive off.
THEN - you will need to use the alignment bar to set the gimbal bearing. Put the alignment bar in as far as it will go through the bearing and into the coupler. Use a large hammer and hit the bar in four directions - up, down, left, right. Then check your alignment.
