Hello,
Very new to the boating world, and I am trying to help get my dads boat back up and running.
Before putting her in the water:
-New starter and slave solenoid. The new starter was different and smaller than the original, but the guys at the shop said it was because that's the way they are being made now. They're the "experts".
Ran great the few times we went out. Last time just as we're pulling in to the dock engine died out. Turned the key and it would crank and it made this terrible grinding sound. Threw the old starter back in and it started up just fine. Went back the next day and it wouldn't start or crank at all.
-Same original starter
-Slave solenoid pulled and tested fine, put back in
-replaced plugs
-replaced batteries and cleaned connectors and terminals
-all the gauges work when key is turned
-turn the key engine clicks but will not crank
The mechanic from our marina asked us to unplug and pull all the plugs and see if it would engage the starter, nothing happened. I think it was to check for water in the pistons, but I can't remember.
Any help would be amazing. Thank you.
-replaced plugs
