auscarter12
- Jun 19, 2015
- 59
I recently purchased an early 70s model boat with a Mercruiser 165 with an early Mercruiser outdrive (Series 1 I believe). I had some work done on the outdrive and had the gear lube changed and the upper unit resealed because of a previous leak. I did not have the lower unit resealed because of the cost of labor, so I decided to take my chances and just reseal the upper unit. Unfortunately, that meant there was no warranty on the upper unit because of the liability caused by not sealing the lower unit. Anyways, I took it out for the first time the other day and checked the gear oil afterward and it was milky white, which obviously means water is getting into the outdrive. I don't know much about the bellows for this outdrive. I know there is a small bellow for the shift cable, then 2 big bellows (one on top of the other). The top bellow houses the U-joint and input shaft, I believe. What does the lower bellow contain? I disconnected it and it is hollow and had some water in it, but I am not sure if it is supposed to have water in it or not.
I am going to do a pressure test of the outdrive tomorrow. I don't currently have the funds to reseal the entire outdrive/purchase a new outdrive. Since gear oil is so cheap, I am considering just changing the gear oil out after every use. I know the leak limits the life of the outdrive, but oil is oil, and as long as it is fresh, would it be a huge issue as long as it was closely monitored? I am not sure of the repercussions of having a leaking outdrive with milky oil. Has anyone ever resealed their own outdrive themselves? Any help? Thanks!
