I've got a 2007 135hp 3.0 mercruiser alpha 1 with the tks carb (bayliner discovery 195). The choke (tks) solenoid stopped working. As a temporary fix I adjusted the idle up slightly and pump the throttle about 8 times before starting. Rough start but is perfect after it warms up. I went to trouble shoot it and there is no power going to the TKS solenoid. It says it gets power from the oil pressure but I don't know where to chase the wiring unless I remove all the harnesses and ties. Anyone have to trouble shoot the solenoid that could lend me some advice...?
