I have a 2008 260 Sea Ray Sundancer (with a 350 Merc), and my question is in regard to the engine alarm. This is our first season with this boat, and have run it without any problems several times this season, but had an engine alarm this weekend. Started up, idled out, started to come up on plane and the engine alarm went off (during bow up attitude). I throttled back and the alarm silenced. The boat idled fine. Tried to rev up to get back up on plane, and engine alarm sounded again. Went back to the dock (with all family disappointed and concerned). The drive fluid was maybe a little low (at "add"), so I added fluid and idled back out. Same problem with alarm when i tried to go back up on plane. Went back in and checked oil level...that was fine. Found the power steering fluid level was low so I added this and thought I nailed the problem. Went back out and had the same problem with alarm. All gauges register that "all good" - temperature, pressure, etc - all reading "ok" and all within acceptable ranges.
Any ideas friends?
Any ideas friends?
