Isaacm1986
- May 20, 2009
- 1,086
I have a 1994 bayliner with a 3.0l mercrusier motor and alpha one gen 2 drive. When I got the boat the putative was making a lot of bad noises. I could hear the u-joints making noise and gimbal bearing howling. I pulled the drive and replaced the u-joints and gimbal bearing. Put everything back together with new gaskets and o rings. I greased up the gimbal bearing with marine grease.
I took the boat out today, and everything was good for the first part of the day. Motor ran great, everything nice and quiet. As we ran it throughout the day, it kept getting louder and louder. I could hear a howling coming when the boat was in a full
turn. We took the boat back to the launch and pulled her out of the water.
I brought her home this evening and hooked up the hose. With it running I could hear almost a "grinding" noise. I added some more grease to the housing and the noise went away.
Ok now for my concern, I'm concerned water is getting into the bellows and has soaked my new u-joints and gimbal bearing. I took a video of it, and there is water coming out where I don't think it is supposed to. Any advice or help would be great. Was planning on taking it out the 4th.
