nope.What's the easiest way to change the bellows on the shift cable?
Any way to do it WITHOUT removing whole outdrive?
It's a 1993 Mercruiser 3.0 I/O
Thanks in advance
To remove that upper half of out drive, just remove the bolts and separate it?
I have changed the bellows without removing the drive. It's tricky and requires a few 'slight of hands', but can be done.
Remove shift cable from shift plate.
Remove black slide and metal threaded rod from shift plate end of cable
Secure a cord to the end of the shift cable, making the connection as narrow as possible
Turn steering hard to Port and tie it there.
Working outside the boat
Remove the end of the shift cable bellows from the gimbal housing (or if you know you're replacing it, just cut it off)
Now carefully pull the shift cable out of the gimbal housing, ensuring the bend it creates with the end in the bell-housing is not too tight
Continue pulling until the cord comes out.
Remove the cord, slide the new bellows and new hose/bellows clamp on, re-secure the cord
Working inside the boat
Pull the cord back up (you'll have to help guide the cable back in)
Have someone else on the outside of the boat ensuring the cable doesn't pull too tight a bend
Reinstall the threaded rod and black plastic guide on the cable
Install the front end of the bellows on the gimbal housing
Perform shift cable adjustment as per my video.
Chris........
hmm, you live near me and wanna make some extra money? ; Jk
So should I ....
A-try to replace just the shift bellow without removing outdrive (carefully)
B- remove outdrive, replace ALL bellows, gimble bearing, u-joint, and shift cable
If Virginia is close to Perth, Western Australia, then sure, why not....
If it helps, on Tuesday afternoon I'll be in New Orleans.... :lol:
lol not quite close enough!
B
Chris.........
