As I mentioned earlier, it is likely not a vapor lock issue. I chased down what I thought was a vapor lock issue for a few years only to find I had a bad fuel pump. I taped the fuel line with heat tape, got a second blower and pointed it at the carb and fuel line, searched high and low for a spacer... I was discussing it with the local parts guy when I was looking for a carb spacer one day and he said "why would your boat all of a sudden develop vapor lock after 25 years?" Lucky for me I found the real problem (with the help of everyone on this forum) after seeing fuel go up the overflow tube from the mechanical fuel filter to the carb, flooding the carb and making warm starts very difficult. I am not saying that is your issue, but it is likely not vapor lock unless someone recently changed something on your boat to make it significantly hotter near your carb and fuel line.
Check your fuel pressure, fuel filters, rebuild carb,... The fact that you have an electric pump feeding the mechanical pump leads me to believe someone thought there was a fuel delivery problem at one time.
