jorgeoliva
- Jun 27, 2015
- 143
Removed the stern drive it's a 2000 alpha 1 gen 2 this is what I found 1. the water inlet looks weird not like all video I have seen were you insert the plastic piece into the hose it has an O ring outside 2. the shift cable has this wire outside need to remove the shift mechanison if I cut the wire can I slip off the shift part so I can remove the bell housing and my bellow has a milky grease on the bottom going to change the U joint bellow anyway has anyone encounter something like this see in next post pictures
