bvetter
- Jun 2, 2013
- 263
Hoping to get some info/advice from the Mercruiser guru's out there.
Engine is a 1999 5.0L TKS, with Alpha 1 Gen 2.
Impeller replaced just last week.
Had the boat on the water yesterday for the first time this season. After running it a while (idling and cruising), I opened the engine compartment to look around and "it seemed to me" the engine and exhaust manifolds felt hotter than I remember in past seasons. From what I remember, the exhaust manifolds always felt cold or slightly warm to the touch, even after cruising around, and the engine compartment was always just warm, not really hot. Yesterday on the lake, the port side was nice and cool (along with water supply hose to it), however the stbd side was hot to the touch (including the water supply hose to it). When I say hot, I mean I could put my hand on the top of the manifold and hold it there for 5s or so before I had to take it off.
Got back from the lake and put the muffs on in the driveway and got the engine up to temp, then bumped up the RPM's to 1200 and let it warm up further. The temps on the manifold and hoses felt exactly the same as on the lake. No difference.
The engine temp seems to be regulating properly, no overheating as far as I can tell. The temp gauge climbs steadily to operating temp (approx. 160F), then levels out.
Here is a pic of the thermostat housing, with the various hoses labelled.
?A? ? Water inlet from impeller
?B? ? Supply to port exhaust manifold
?C? ? Supply to stbd exhaust manifold
?D? ? Recirc supply to engine water pump
Here are some of the tests I did in the driveway:
SO, is what I am seeing ?normal?? Is it normal to see the stbd exhaust manifold hotter than port side?
- Removed t-stat housing and inspected, all looks ok, no blockages as far as I can see.
- Removed t-stat and tested as per SELOC manual in pot of hot water with a thermometer. Opens and closes as expected. Thermostat rating is 160F.
- Engine off, removed water inlet hose (A) from t-stat housing, directed into 5 gallon pail. With muffs on the outdrive and water turned on, started engine and set to idle. Water flow started coming out of hose after about 5 seconds or so. Rev?d up to about 1000RPM, water flow increased to a pretty good rate. Ie: water flow proportional to engine speed. Only ran for about 30 seconds total for this test.
- Engine off, removed supply hose to port exhaust manifold (B). Connected it to a garden hose and turned on water, good flow coming out of port side exhaust hole behind transom plate.
- Engine off, removed supply hose to stbd exhaust manifold (C). Connected it to a garden hose and turned on water, good flow coming out of stbd side exhaust hole behind transom plate.
