Hi Guys,
I've got a 1984 Glastron with a 140hp 3.0. It was winterized and not used for about 6 years. The other day I changed the oil and OD oil, and tried firing it up.
I've got 40psi oil pressure when cranking, but it won't catch.
I then did a compression test and got 90, 0, 0, 90
I took the valve cover off and found that the two exhaust valves on the two center cylinders were stuck open. Rockers and pushrods are fine, the valve is literally rusted to the guide in the open position.
I don't know if I want to rip the head off and have it re-done, or just part out the engine.
Are these interference motors, as in, with the valve open would it have smacked the piston while I was cranking it ?
-- Joe
-- Joe
