supercab78
- Sep 6, 2004
- 158
I have a slow water leak into the hull (about 1/2 gallon an hour) in 1993, 4.3 v6 gen II setup,, low hours & all fresh water use. It is stored on a trailer. It is not either bellows(new now but they weren't bad upon disassembly), trim wires or speedo tube. From what I can tell it's coming in BELOW the exhaust tube that passes through the transom. Yes the drain plug is tight. I can not find an exploded view or a picture of how the tilt lines pass through the transom. Is it even possible for it to leak water in there?
