hello, I recently purchased this boat, everything looks great and it starts right up, buuut. withing 2 seconds from starting the oil pressure guage pegs out at the top"80psi" and if I don't shut it down it will blow the seal off of the oil filter.. if I shut it down and restart over and over until temp gets up to 150F I can run it but it is still at 79PSI this is all at idle, I don't believe a bad oil pump pressure relief is the culprit, because pressure shouldn't need to be relieved at idle.... have tried SAE 30 rotella, standard 5w30, and 20w40 quicksilver all with the same outcome, also with Mercruiser oil filter and fram ph30. HELLLLP!
