rca1pollock
- Jun 25, 2014
- 42
im probably going to GIVE UP!! thought i had SOLVED the problem by adding 1.2 ohm resistor before coil. have 3.3 ohm coils and 1.2 ohm resistor. brought coil input voltage down to 12v while running.. ..guess what? she died 3 times requiring me to swap out for cold coils each time. should've kept my old points ign!! like a DUMMY..i even threw out the plate&cond&points! i'm getting good readings on coils when they're cold. and they aren't getting as hot..but still getting to NO spark condition and OPEN coil after running for while. thought about CALLING pertronix..but will probably get different answers from different techs. could bad e.i. module be ok at first..then not give spark or maybe coils readings look good when cold but fail after getting just WARM now. I MAY just throw a new IGNITER 2 and coil at it. or maybe go back to points?? WHYCAN I TROUBLESHOOT A WHOLE LOCOMOTIVE @ WORK but can't figure thiis out?
