cheyenne81
- May 28, 2015
- 3
Hi All
Just joined, glad to be here. Just took the boat out of storage and started it and heard a squeaky noise coming from the flywheel when running, I had water hooked up correctly and also noticed water leaking from the inspection cover from the flywheel where the noise is at.
97 merc 3.0 with Alpha one drive.
It did not do this when used it last year, I am at a complete lost trying to figure this out? I didn:t think water should be leaking from the flywheel area?? anyone have a similar problem
thanks in advance
kevin
thanks in advance
kevin
