Well the islander out drive has been more of a disappointment then I was hoping. It was running hot. So changed motor thermostat. Bellows were cracked so removed every thing and replaces all bellows, the water hose in there and Gimble bearing was good. Decided to redo the impeller so tor the lower off and it was really shot. It had been overheated and the impeller was melted and case was shot. So replaced them. Plus the oil seal. Before assembling I looked into the top section and the rubber seals at the entrance of were lower shaft goes was melted and distorted too.
So thought about replacing seals, but the one looks like a teardown to insert from the inside. So my question is, isn't there a good chance since it was so over heated that bearings and all rubber in side is gone also. At least that's what my reasoning seems to be. Wondering if a used alpha one out drive with my new impeller wouldn't be better.
Also would size of motor dictate the type of Alpha one I need? Mine in a 1989 mercruiser with an Alpha one but not gen II. Would one off a v8 or v6 fit mine with the 190? Seems drive should be same. Also whats required to change an alpha 1 to a gen II?
