I have a Mercruiser 350mag Bravo 1. I've recently started getting a double beep after cranking every 60 seconds then after 2-3 minutes of engine runing, the beeping stops. All fluid levels are normal and engine runs fine. Any thoughts?
:welcome: to iboats
Could sure use more info. There are so many variations of 350mag mercruisers it is hard to start helping without more info. The best thing is the engine serial number, the next would be the year. If the year is provided, we need to know is it carb or EFI
