1996 454 Magnum MPI with the VST system
Engine # 0F802536 Model # 4454118JT
Thought the alarm was low gear lube sensor and ignored it for about 8 minutes until I glanced at temp gauge and it was way up and smoke was coming from engine compartment. I shut down at that point. I know, stupid but have to deal with it..
Lost the belt to the raw water pump due to bearings in the idler tension pulley failing.
I have the pulley on order and plan to replace pulley and belt. I have not tried to start since it overheated. Was going to wait for parts.
QUESTION. Anything that I should look for or check before trying to start? Any easy way to check for cracked manifolds, gaskets, etc. prior to starting? Oil on dipstick looks good.
Once I get that far I'll be back with more questions.
