HI,
I had a seal go on my Alpha 1 Gen II leg letting a small amount of water enter the gearbox. Fortunately I caught this early. I found the compromised seal and replaced it/ pressure tested etc... Now I'm having a devil of a time getting the last of the water-contaminated drive oil out of the system. I have the remote oil reservoir at the engine so those lines really should get cleaned out/ flushed as well.
Who has good advice for me on how to best accomplish this? So far I have flushed with gear oil into the leg (off the boat) and then turned the drive shaft for a while to spin the gears and distribute the oil, and then re-drained. After several repetitions of this I still have traces of contaminated oil in the drive!
Peter
Peter
