D.doctorick
- May 25, 2015
- 11
1993 mercruiser 454 in a chaparral villain III had water in oil. Tore motor down found bad gasket. Had heads sent to machine shop. Put all back together. Now it won't start. I have fuel. I have spark. I verified timing is correct, 0 degrees tdc for starting purposes.
Boat has cam(don't know the specs), 9.5:1 pistons, 502 heads, roller rockers.
Ran perfect before. Had got it to fire once but it was rough and not on all cylinders.
Thinking it could be valve issue?
Anything will help. Thanks.
