Crew,
I'm doing a bellow's job and the "Retainer Screw" on the Shift Slide / Fork is so corroded I was not able to get a tiny tool in the slit and have tried drilling this "Retainer Screw," out and I have it drilled down about 3/4 down.
Has anyone here dealt with a severely corroded "Retainer Screw," on the Shift Slide Lever that holds the shift cable inside the outdrive?
If yes, how did you get it off?
I can't get my bell housing off until I get this junky retainer screw out.
