Hi its a bayliner 212 - was very low speed, 6 knots river - engine smooth and runs fine idle and onto plain - so there is no 4 bleep alarm for this model ? - Im running HDS 10 sounder with structure scan, this goes off when keyswich turned off so rules this out, definitely continued after key off only silenced with battery off, ! also carbon monoxide standard fitment - had not given that a thought and have no idea what that sounds like ! I will need to check this later. Will also check main power relay as above if monoxide alarm is not the issue.
