brian4321
- Jan 19, 2014
- 359
2000 bayliner w/ 5.0 mercruiser alpha gen two...when shifting into reverse it goes in quick and clean with no grinding but when shifting into forward I have to move the shift lever several inches before it fully engages and I have to do it quickly or it grinds ...I can shift into forward fine with almost no grinding but if someone else drives that isn't used to it ,it grinds more than I like...should i try adjusting the cables or is this normal? Thanks in advance
