littlejrs
- Sep 20, 2006
- 10
I have a Mercruiser 5.0L MPI Bravo engine and recently I have had problems starting my boat. The first time I had an issue, I couldn't get it to start at all and gave up as to not drain battery. I took in to the mechanic and they stated it started right up for them. I asked them to check the connections, ground, batteries and they found nothing and the problem I had did not happen for them. I picked it up and took it for a weekend trip. The first two times I started it, it fairly quickly. Then after driving it for 2 hours and then letting it sit for 1-2 hrs, I had a problem starting it. I had to push the button on the throttle and push it forward (wasn't sure the proper terminology) and it started right up. I have noticed that when going at slow speeds, it doesn't seem to run as smooth as it used to but so slightly it wouldn't be noticeable to anyone else. I was told on the trip that it was the IAC. Replaced it but problem still happening, but not every time I try to start it. So I again took it into dealer mechanic and again they state it started right up for them.
On a side note as I am not sure if it's related. I used to keep the gas tank full and put Sentry fuel treatment in it. More recently it has not been completely full and I hadn't put the fuel treatment in it in the last 1-2 yrs (so bad with time frames). The tank is now down to 16 gallons as I was trying to empty the old gas before filling with new gas and I went ahead and added fuel treatment to the remaining gas.
I am at a loss.... Believe it in either the fuel or the ignition system. Anyone have any experience with this or best recommendations of how to narrow it down?
