center bolt's generally come with a rubber gasket - just install and be done. if its a perimeter bolt, and you did not buy a rubber gasket, head to the autoparts store and buy a set of rubber gaskets for your SBC and install.
Ok so I broke one of the bolts trying to remove. Then I drilled it out and tried to tap but the tap broke. Had a mechanic Truro tap after the broken tap was removed and it broke again. What do yall think about three bolts and rtv on both sides of the gasket?
Sincerely
~A beaten man
