Mkos1980
- Oct 25, 2007
- 640
Last year had no problems so this year I went to change the oil since I ran out of time last year only to find some traces of water... I pulled all 4 plugs on driver side. Looks nice and dry. I pull all 4 on passenger side and all wet. I pulled the riser off to find a saturated gasket and coolant in the bottom of the manifold. I Pulled The Manifold And Numbers 3 5 And 7 Exhaust Ports Had FILLED Up With antifreeze and number 1 ex valve was open so the piston had coolant in there. Is it safe to say the riser gasket is the cause of this? Manifolds are glm Aluminum ones I installed in 07. Zero pitting on manifold and risor. I did not run the motor once I filled the motor up with antifreeze.. 1990 mercruiser 350. 260hp
