Hi everyone, I recently pulled my drive and had the upper resealed, and purchased a brand new OEM lower. Put everything back together. When checking the shifter while the engine was running, there was a knocking sound coming from the outdrive in forward and reverse, nothing in neutral. However when I removed the propeller, the knocking sound went away. Before I call a mechanic to check it out, I was just wondering if this sound is normal? I know there's a little normal back and forth play on the prop shaft and the sound is similar, just want to be sure before dropping it in the water.
