jaybrassmonkey
- Feb 19, 2015
- 74
I took part the Outdrive to change the impeller. Had all back together but had to take it apart again (forgot to shift into forward). Got that starightened out but noticed I had blue lube leaking down from where the drive shaft of the lower unit should go. Will that seal up when I put it all back together. Don't think I got EVEYTHING drained out before I started working on it.
And I found it easier to reinstall upper to boat then lower to upper. Any problems with that?
