Performed a tune up on my 18' Crownline with a 4.3L thunderbolt V Mercruiser I/O. Replaced the distributor cap, rotor and spark plugs. Initially the motor would not turn over; it just cranked endlessly until I applied some throttle and it finally turned over but would not stay running and died after a second or two. After a few minutes of this, I'm worse off now as the motor is not cranking anymore and the starter is just spinning. I'm fairly certain I reinstalled the plugs correctly since I installed the new distributor without unplugging the old one and one by one plugged in the new cap. The rotor is seated as far down as it'll go and is identical to the old rotor. Also, I was thinking maybe the battery could be bad but I had it on the charger all night. This past weekend, before the tune up, the engine did crank to idle so I'm thinking it's not the battery. What mistake(s) could I have made to get in this situation and ultimately how do I go about diagnosing and fixing the problem?? Thanks in advance for the help.
