73Marauder
- May 20, 2014
- 9
I am attempting to remove the "NAILS" that retain the pins for the bell housing and have broken off the head of the nail. I have tried everything I can think of to loosen the pin. Made a needle nose vice grip plier slide hammer puller, tried to drive the pin through, gently heated the gimbal ring around the pin and it hasn't moved. I am at my wits end any other ideas? and yes I did take the time to straighten the pin where it protrudes from the front of the gimbal ring.
