I just got done replacing my raw water impeller on my 2005 5.0 MPI W/ Bravo3 Outdrive. I got everything back together despite Mercruiser and Searay's best efforts to make the pump nearly impossible to R&R. I was re-attaching the positive lead to the alternator when I hit the dipstick with the other end of the wrench. I got a good spark from that. Yes I should have shut the batteries off but I forgot. I went to start the engine and I received the normal singular beep but the Smartcraft gauges failed to power up. When I turned the key to the start position- Click! from the start relay. Nothing else. Clearly I've blown a fuse or tripped a circuit breaker (Hopefully). I've searched high and low and can't find a fuse that's blown. The three little 20 amp fuses underneath the little cap located next to the ECU are fine. The ignition fuse under the helm is good. The 50 Amp circuit breaker on top of the engine seems fine as I don't think it's popped. I can't push it in. In any case there is only 3.7 volts running through it. The only other fuse I can think of is on the starter and I can't even see the starter! The boat is a 2005 Searay 220 Sundeck.
