I need to order a new distributor for my motor. The previous one is damaged beyond repair.
I looked around and decided on the David Unified Ignition system.
However, when I go to order it, they are asking for information that I don't know. Things like...
Compression Ratio
Cam Duration
Valve Lift
I guess they do this so that they can set the distributor up before sending it to you.
I cannot find anywhere that this this info. I looked in the must have info for DIY'ers and the Adults Only sections of the site and I gave google some attention and treid to search that way.
No luck.
Could anyone help int me in the right direction?
Thank you!
Compression Ratio
Cam Duration
Valve Lift
No luck.
Thank you!
