91 BAYLINER 4.3 SHIFTS FROM FORWARD INTO FORWARD INSTEAD OF REVERSE. WORKED LAST SEASON. GOING TO TAKE IT TO REPAIR SHOP. ANY HELP OR SUGGESTIONS?
Ayuh,..... Welcome Aboard,.... Loose the Cap-lock, 'n you'll make more friends, as nobody likes to be YELLED AT,......
What do ya mean, it shifts from Forward, to Forward,..?? is it just stuck in Forward,..??
When ya move the lever on the controller, do the cables at the shift switch on the motor, move,..??
With the tiny bit of Info you've provided, I'm guessin' the lower shift cable is worn out/ stickin', 'n needs replacin',...
