IanFS
- Apr 21, 2009
- 188
Hi all
I've tried long and hard to find a Power Piston to fit into my Mecarb 2BBL including many used marine depots. I was about to order a Recon Rochester Carb which would fit when I have seen a 4BBL inlet manifold on Ebay and a Rochester 4BBL carb for almost the same price as a Rochester 2BBL carb.
What would be the problems fitting a 4BBL Carb e.g. throttle fittings, gear cable fittings. Also would the engine run ok?
Cheers
Ian
Cheers
Ian
