Hello all, I've spend a LOT of time looking all over the web for some help on this issue but nothing seems to be exactly the problem I'm having.
So heres the problem:
Its a pre-alpha drive model number 2680066 on a mercruiser 120hp 4 cylinder engine. I did all the bellows, gimble ring, and water pump before taking it out during the summer. At the end of the season was giving me a really hard time shifting into reverse. It would grind but if I went in and out of reverse a couple times it would eventually engage. It really only happened for 2 outings then I pulled it in for the season because I didn't want to cause extra damage.
What I've done so far:
I replaced the throttle cable, lower shift cable, lower shift shaft and bushing/seal and did a ton of adjusting trying to get it to engage cleanly. I then assumed the problem was in the drive so I dropped it off at a shop because I didn't want to buy more tools and I wanted a professional opinion. They changed all the seals for me in the lower and said the gears look fine. In the mean time I bought a whole other outdrive (same type same engine upper and lower) and slapped that on there. Same thing. So now I'm leaded to believe the problem isn't in the outdrive at all.
And heres some troubleshooting I've done:
I've taken the lower shift cable off the shift mechanism to pull and push the cable manually. Forward goes in easy and reverse only starts to engage at nearly the end of range of motion of the cable. I can physically verify that the bucket shaft and lower shift post are completing their range of motion because the bucket goes far enough to hit the housing of the drive. Which points to the problem being in the lower unit.
My current theory is maybe when I put the new lower shift shaft in the lower unit that maybe its directional and could be off a tooth in the spline? Has anyone had any similar experience or input?
Thanks for your help
Adam
Adam
