I'm hoping someone can provide some advice on this. I have a 1998-2001 Mercruiser 4.3L 2BBL (Service Manual 25 engine) that is leaking gas from the electric fuel pump. I haven't been able to determine where it's leaking from. While on the boat, I've gone through and tightened all the fittings (inlet and outlet flare fittings at the fuel pump; and the o-ring sealed "adapter" fittings that convert from the flared fitting to the fuel pump fittings (3/8-24 and 5/8-18), it still is leaking. I pulled the pump off the engine, and inspected the fittings, no obvious cross threads, o-rings looked fine.
My question, does anyone know if the pump could be leaking internally (i.e. between the brass part and the aluminum metal housing)?
