xeke123
- Jan 31, 2015
- 9
Hello!
Have a old Sea Ray and am in the midst of replacing bellows and gimbal bearing and am uncertain on how to proceed with replacing the shift cable bellows and or replacing the shift cable. I have a manual and have done internet research on how do do the project, but it seems the cable I currently have on now (which is the old style with the lock nut located on the forward end of the bell housing) has a support tube that is "crimped" on to the core wire. Not sure if this is the way it is supposed to be on the old boats, but I do not know how to get this off the core wire, so that I can pull the wire out of the cable housing...
Prior to the bellows project, I have had very few issues with the shift cable and am not certain that it actually needs to be replaced, however, I need to get it off to either replace it, or to get the new shift bellows on.
I am attaching a couple of pictures of the top or forward part (which attached to the engine) of the shift cable with the cable end guide removed.
My questions are:
1.) How do I remove this shift cable so I can replace the shift cable bellows?
2.) How do I determine if the shift cable needs to be replaced?
Any guidance would be appreciated!
My questions are:
