Wellcraft170
- Aug 11, 2008
- 147
hows it goin guys? been thinking about it over the course of the winter so far but originally my first problem was basically when i first get out on the water everything is perfectly normal. then if i stop for a few minutes and try to go again the engine will stall when i put it in gear (forward or reverse). the engine will start back up but have a really bad idle and eventually stall as well. right before it stalls i would try to put it in gear but it'll still stall. the even weirder part is that after this happens, you can wait again till it cools off and everything goes back to normal until it gets hot again.
