I have a 1995 Proline with twin raw water cooled 5.7 V8s. The risers and exhaust manifolds are clean with no obstructions. Yet, I have been experiencing odd temperature reading one my stb engine gauge, and before I started pulling sensors and gauges, I wanted to measure with another device. I also have a laser thermometer that I tested the heat coming through motor and manifolds. What I found was odd. The stb side of the center water manifold was about 20 degrees warmer than the left side near hoses going to risers. This is water coming directly from OD, circulating pump and not via inside of motor. I examined each temperature sender with laser and they read about 120 each but metal nipple on stb side is 20 degrees warmer. The helm gauge registers 140 degrees. I replaced stats last fall and center manifold appeared clear of any obstructions. Stb top of riser appears a bit hotter than port rise. Unfortunately, I cannot get laser inside boat to aim at top of risers, but the stb feels a bit hotter to touch. I suspect the plastic insert that aids in centering stat to metal housing is getting off centered, even though it is somewhat pressed into position and has an indent. Next test is to pull top hoses and visually compare water coming out. If water flow is about the same, any other suggestions would be appreciated. If not, I have my answere. Pull stat again!!!!!.
