rough rider
- Jan 12, 2015
- 27
I have a 1978 Galaxy tri hull. It has a mercruiser 898 with a 305 engine. Using a rochester 2gc carb.
My problem is that it runs fine on the trailer but when it is in the water and I try to take off it just bogs down and will not get over about 2,000 rpms. This was a problem a couple years ago and I had the carb rebuilt and it fixed it but could it be anything else? I changed the plugs and wires and the coil. Then installed the old coil back on to see if it made a difference and it did not. I keep playing with the timing but it just never seems to do any good. It also seemed like it used A LOT of fuel for the time I was out tinkering. About 7 gallons for just a couple laps around the ski area. ( Probably about 3 miles total) Could it be something with the float? It has ran great for two seasons with only the basics taken care of. This time I changed the water pump in the stern drive, the coil, the plugs and new wires. Now I have a whole new problem. I should also mention that the idle mixture screws make no difference in how it runs and I have never been able to get it to run good at the suggested 8 degrees BTDC. it has always been more like 15 degrees BTDC and it would ping a little wide open but it would always start reliably and run fine other than slow out of the hole.. Any help would be great.
