I am rebuilding my trim senders limit and position. I do not know where to hook up the wires once you pull them through the transom. I have the manual but it doesn't say anything about the wiring. Please advise.
The Trim Limit wires run over near the trim pump and plug into the blue and purple wires.
The Trim Position wires will attach to a ground and a brown wire with a white stripe (gauge sender wire).
