brian.fischman
- Nov 18, 2014
- 1
Greeitngs
I'm in the process of replacing the impeller on my alpha one gen II (1994), i've got the kit, and i believe i have the impeller correctly installed. I have a couple of questions
1) the seal/gasket that goes around the shaft out of the water pump assembly, can i just pop this in before i install the water pump? it doesnt seem to want to seat using the tool
2) the sleeve and plastic guide are in the upper half of the unit and using moderate force do not want to break free, isn't this suppose to come off and be attached to the pump housing? should i go for bigger tools and maybe a hose pick to pull it off?
Its going to be raining the rest of the day here, so i'm in no rush, but would love to have it buttoned up and tested first thing in the morning so i can continue to hunt the illusive rock fish.
thanks!
thanks!
