OK time to start saving you some money LOL. To replace an impeller yourself you would need impeller kit $35, outdrive oil (2 qt) $12, and a outdrive service gasket set $10. Take it to a mechanic and you are looking at a couple of hundred dollars. You will need a few tools, good socket set a torque wrench and an alignment tool couple of inexpensive grease guns and a pump for the outdrive lube and a few other common tools. Here is your engine manual: http://boatinfo.no/lib/mercruiser/manuals/mercruiser8.html#/0 and your outdrive manual: http://boatinfo.no/lib/mercruiser/manuals/mercruiser6.html#/0 You also should have a good digital voltmeter and timing light. The impeller is in the outdrive, so you need to pull it off, but it is not that hard. It is handy to have a friend (not wife) to give you a hand pulling it and reinstalling. Learn how to pull the outdrive to do routine maintenance and you will save many hundreds over a few years. Lots of guys here to help. good luck.
