1987 mercruiser 3.0 is stuck. Can't turn.
benzoc
1987 mercruiser 3.0 is stuck. Can't turn. Have tried to trun power steering pump with number 1 plug removed. Has short block installed 2 years ago. Winterized evrt year since.Starter will not engage flywheel and I don't want to damage engine. No visible cracks and oil is clear. How can I manually turn engine
Welcome aboard.
first, pull the drive to make sure the drive isnt locked up. then pull all the plugs and you should manually be able to rotate the motor by grabbing the belts by hand.
also, take the starter off and have the starter serviced.
thumpar
Do as Scott said. It could be the engine or the drive is locked up. You need to find out which one before going further.
Alumarine
Do you think it's seized or do you just want to know how to rotate it without the starter?
Bt Doctur
the starter should be able to spin the motor, if it dosent engage the flywheel that's another issue
remove the drive ,using a old inputshaft with a T extention welded to it ,insert into coupler, turn engine.
if it was winterized properly, it should still spin.remove all the plugs and insert some medical swabs(the long ones) into the cylinders to check for water or rust.
BruKen
Any luck with this yet? This season past mine sheared a starter motor bolt and the starter rotated slightly jamming up the works. Coincidently a couple of others here at the same time had a similar issue.
