KnotConnected
- Aug 15, 2012
- 221
Hello!
Mid summer this past year I had some significant problems shifting with my 1994 Bravo 3, leaving to a complete rebuild of the upper, and an inspection / a few bad parts swapped from the lower. Many of the parts in the upper, including I believe the upper gearset, were fine yet had to be replaced because of a single small bearing or part that failed and needed to be replaced (The marina said the bearing itself could not be purchased, an entire upper gearset including the replacement bearing needed to be procured).
So I'm left with a box of likely good parts, sans a small bearing. Can anyone help identify what these are, and what I need to do to inspect them to insure their integrity for used resale? Part #1 i believe is the outer prop shaft, and was replaced because of the infamous groove, so Im not sure if there's a use or any re-use in that, but if any of the other parts are bad I certainly want to disclose any potential issues during resale.
Thanks all for the input!!
http://i46.photobucket.com/albums/f117/n915aa/IMG_20141207_181250_zpse21e58ee.jpg
http://i46.photobucket.com/albums/f117/n915aa/IMG_20141207_181201_zpsabc09f99.jpg
http://i46.photobucket.com/albums/f117/n915aa/IMG_20141207_181320_zps2674fdb6.jpg
