I'm removing both 305 from of my 83 Searay 270 and replacing them with re-manufactured 96 5.7 crate motors. The salesman told me I needed to stay with the 12 3/4 inch flywheels because the 14 inch might have clearance problems. So they installed the 12 3/4 inch flywheels before they shipped the motors. Now the problem is the 12 3/4 inch flywheel uses a starter with a straight bolt pattern and the 14 inch flywheel uses a starter with an offset bolt pattern. My 96 blocks have an offset bolt pattern. Does anyone know of a starter with an offset bolt pattern that works with a 12 3/4 inch flywheel. Thanks
