Made it interesting to dock boat today. Is this an adjustment issue, or a larger problem? Does anyone have a link to correctly adjusting the cables? 91' Larson with alpha one drive.
Ayuh,.... Before ya go adjustin' things, check the wirin' for the interrupter switch 1st,....
Push the button/ lever 'n see if it'll stall the motor,....
Gracious alldodge. I just downloaded and read through the entire OMC manual linked here and couldn't find the adjustment. Plus I am a newbie here and having trouble navigating this sites waters. I really did try to look for the achris section.
Maybe I mistyped. Its a 4.3 mercruiser. 91 Larson. So, I made the adjustment according to the PDF sent. I followed the directions. Forward works great. shift interrupter switch works then goes back to center as I throttle. The shift interrupter switch engages in all aspects of reverse. Soooo. I looked for discrepancies in the manual to my application. I have the plastic shift bracket. However, my cable that goes to the remote is adjustable. It has a threaded rod and a smaller brass jam nut. Both of which are loose and turn freely. I assume the problem lies somewhere in there. As I put it in reverse, there is a lot of pressure pushing the shift bracket. Which translates to tension on the interrupter keeping it engaged. Not letting go. Any ideas? Or am I looking at just getting another cable? I am a don't replace it until its broken kind of guy.
...Forward works great. shift interrupter switch works then goes back to center as I throttle. The shift interrupter switch engages in all aspects of reverse. ...
yes, switch does work. I tested that first. I can tell the guy I bought the boat from had issues with this and must have given up. He had a ground wire going from the switch to ground out the distributor because he could not turn of the ignition. I posted on another thread about that issue and got it fixed.
The linkage does a weird thing. Let me explain in long winded form.
Before and after adjusting; I push the throttle forward, it engages the drive, I throttle up, but past a point the linkage to the card drops back and then kills the ignition. That is pushing it all the way until it stops. Same in reverse. So, I might have multiple issues, or it may be working to protect the engine. I watched the video on adjustment. But am still unclear, Do I stop pushing the throttle in forward as soon as it goes into gear to adjust that cable? Or do I push until it moves the linkage on the carb into full throttle?
