jayhanig
Master Chief Petty Officer
- Jun 27, 2010
- 836
I have a bad tendency to convert working equipment into expensive paperweights. Before I pull the thermostat cover off, I'd like to have at least a replacement gasket available. Identifying what I've got without opening it up has been a challenge. The service manual says to use a 140 degree thermostat for an open water system and a 160 on a close cooled engine. Mine is open cooled, only two years old, and has always been flushed with Salt Terminator after every use.
What I'm curious about is that once warmed up, my engine runs at 175 all the time; no matter whether at idle or on plane. If the proper thermostat is a 140 degree one, does it seem reasonable that the engine runs 35 degrees warmer? It has always done this. It seems to me that although the thermostat might open at 140, there's nothing to say that the ultimate temperature reached would be the same. So the question becomes: how much higher than rated opening temp should the engine operate? What is to be expected?
The engine is a 1998 GM built Mercruiser 3.0 liter four cylinder. And while you're considering this, does anybody know off the top of their head what part number gasket and potentially thermostat I need for this? I'm inclined to think my thermostat's OK but I know I'll need a new gasket if I open it up no matter what. I tracked this down once in the past but now I can't find the information.
