Ok so I have a 1985 chris craft commander 333 with twin mercruiser 340 inboards. Its been sitting for two years. The gas tanks were cleaned and drained when the boat was laid up . Basically the system is this. The lines come off the tank into eachother, and up to the water seperator, then the fuel pump pulls in from the separator sending it to the carb. I cant get fuel to the water separator. I ran both engines off a 5 gallon can (pulled the line off the water separator and put a hose on the separator into the 5 gallon can) it pumped fuel up from the 5 gallon can no problem. They are 100 gallon tanks on each side of the boat I have 12 gallons in each right now. Its kind of a long run and they were completely drained and the lines were blown out.....should my mechanical fuel pump be able to pull it up from the gas tank ? Its about a 7-10 foot run. Should I find a way to try amd prime it ? Not sure what to do......
